Have you heard of this? Expert opinion please..
Old Oct 13, 2006 | 05:27 PM
01Z0H6's Avatar
Default Have you heard of this? Expert opinion please..
Here's the situation...
Had my motor rebuilt ( cracked block "resleeved").. Since then the car has been burning coolant.. replaced radiator,t-stat(twice), water pump, check relays, fans, hoses, etc... NO leaks @ ALL!! Car runs great...
The "shop" pulled my heads and found that infact the sleeve did not seal properly allowing the water to pass through the water jacket's...
Here's the deal.. They are proposing to drill the hairline crack in the block, thread it, place some sort of screw in there and grind it "i guess" flush to the block... they will use the Fel-pro gaskets..
Have you heard of this? Any experiences appreciated...
Thanks..
Old Oct 13, 2006 | 08:05 PM
strokedls1's Avatar
Doesn't sound like the right way to fix it. I would change out the block.
Old Oct 13, 2006 | 08:13 PM
White_Hawk's Avatar
So you want to screw in a press fit sleeve? Run!!!! What is the old bore and new bore size?
-Geoff
Old Oct 13, 2006 | 09:38 PM
Wnts2Go10O's Avatar
take it back to the shop that put the sleeves in
Old Oct 13, 2006 | 09:47 PM
FirstGen's Avatar
Two things will happen. First, the crack will come back and be even larger. Second, you will be buying a new block after all the extra down time.
Or you could bite the bullet and get a new block. I can't tell you how many issues I've seen with re-sleeved blocks other than factory...
