LS7 Heads and Intake on an LS1, Will this work?
Old Oct 16, 2006 | 02:24 PM
pArTy b0y!'s Avatar
Default LS7 Heads and Intake on an LS1, Will this work?
Okay, so here is what I want to do. I have the Chance to buy LS7 Intake, Fuel Rail, Heads, Rocker Arms and Valves. I currently have a 2001 Camaro SS. It has Stock LS1 Parts except Katech Rod Bolts, but I have it bolted to an Aftermarket K-Member. So here are my Questions.
Will the LS7 Heads Bolt to the LS1?
Will I need a diffrent length set of Pushrods?
If I use the LS7 Intake and Fuel Rails, I know I cant use the LS7 injectors so what Fuel Injectors will work?
I replaced the Throttle body with a Holly 90mm since the LS7 Throttle body is Fly/By/Wire and I need Cable Control, but will the power steering bolt to the head since the LS7 has the Alternater bolted to the Head?
What Head Gaskets would I need?
How does the Exhaust bolt up?
Basically has anyone attempted this? I dont mind doing some modifications however if I can't be done I dont want to find that out while I have my car in parts. I hope someone can answer my questions. I recieved these parts for free so it would be awsome if I could somehow pull this off.
Old Oct 16, 2006 | 02:27 PM
Wnts2Go10O's Avatar
no, your bore is too small
Old Oct 16, 2006 | 03:19 PM
Beast96Z's Avatar
The heads won't work on the stock LS1. Those heads were designed on a 4.125" bore, your is 3.898". Basically, you need a big bore motor.
Old Oct 16, 2006 | 09:41 PM
Ferocity02's Avatar
Basically no, as said, you need a larger bore on your block.
Other than that, they are pretty much a direct bolt on with a few additional things needed. I've done it.
