ls2 intake what do you think
Old Oct 18, 2006 | 12:40 AM
bad intentions's Avatar
Default ls2 intake what do you think
i just got an ls2 intake for my 6.0 how much better is this than the ls1 and can i use the ls1 fuel rails on this ls2 intake..
Old Oct 18, 2006 | 01:23 AM
Blown04Z06's Avatar
i dont think you can use them together. i remember lt1dave telling me they have to be modified to work. pm him for details
Old Oct 18, 2006 | 10:59 AM
AppleMac's Avatar
Why don't you get a LS6 intake?
Old Oct 18, 2006 | 11:39 AM
Steve1969LS1's Avatar
LS1 fuel rail will not line up to a LS2 intake. You would need an LS2 fuel rail or maybe an aftermarket fuel rail (I heard FAST was working on this).
If you use an LS2 fuel rail you will need LS2 injectors. Which will also require adaptor plugs..
Call Katech, they might have adaptor harnesses. Besides
FAST>LS6>LS2>LS1 in terms of which intakes perform the best.
Old Oct 18, 2006 | 12:14 PM
See5's Avatar
You can make LS2 intake work with LS12 fuel rails buy shimming or cutting and adding crossover hose. Will need new injectors or o-rings as mentioned.
If you port it it might be as good as an LS6.
Old Oct 18, 2006 | 03:13 PM
AppleMac's Avatar
Yup... I am running a Fast with my LS2 Fuel Rails...
Old Oct 19, 2006 | 01:06 AM
Default not ported
well i dont think am going to port i just now still want to leave some mods for later but i said i would give this intake a try just cause will the ls2 with 90mm tb and its new..
