Fly-cutting for the L92 heads - Question
All help greatly appreciated.
Can you give us an idea of duration and advance? It would help others choose a cam that don't want to flycut.
Aftermarket stainless valves virtually all of which have a thicker margin or edge will make p/v clearance a real issue with even mild cam grinds.
Good luck.
Richard
Bret
Nate
Nate
Nate
Nate,
If you want to do this then LEARN what it takes to make a accurate guess at that and you can do it on your own then.
Bret
Problem here is the 2.200" valve relief that is needed for these intake valves.
