ls1 vs ls2 weight?
Old Oct 21, 2006 | 04:50 AM
RHDV8's Avatar
Default ls1 vs ls2 weight?
Hi guys,
Just wondering if anyone knows the weight of a LS1 compared with the LS2?
I've read that the exhaust manifolds were lighter on the LS2, but discounting them, any differences?
Old Oct 21, 2006 | 07:53 AM
Stang's Bane's Avatar
Should be minimal if any, I would say 5 lbs at most either way.
Old Oct 21, 2006 | 08:07 AM
Phoenix_Master's Avatar
From what I know:
LS1 weighs 460
LS2 weighs 450
Old Oct 21, 2006 | 10:05 AM
AppleMac's Avatar
Yah, there is no reason for them to be any big difference in weight...
Old Oct 21, 2006 | 03:00 PM
RHDV8's Avatar
Thanks guys, learning all the time.
Old Oct 21, 2006 | 06:31 PM
strokedls1's Avatar
Makes sense that it is lighter because it has less mass on the block with bigger bores.
Old Oct 21, 2006 | 07:09 PM
bad intentions's Avatar
Default iron 6.0
what about the iron 6.0 cause your talking about the aluminum hope i spelled that right...
Old Oct 21, 2006 | 07:18 PM
AppleMac's Avatar
I don't believe there is an iron 6.0 LS2 or LS1
At least not that I know of...
Old Oct 21, 2006 | 08:08 PM
Mazdryk's Avatar
I looked it up a long time ago and dont remember where I found the INFO but the LS2 is 15 lbs lighter than the LS1. This is 100% accurate.
Old Oct 21, 2006 | 08:46 PM
Default you might be right
i think the only iron blocks come from the trucks but they are ls1-2 style...cause all the same parts bolt on....
Old Oct 21, 2006 | 09:57 PM
Brainful's Avatar
Iron 6.0 L is presented since 2001 as the LQ9 .
Old Oct 21, 2006 | 11:23 PM
AppleMac's Avatar
I dun think they make an iron LSX 6.0...
However there is an iron LSX 408 which is very heavy.
Old Oct 22, 2006 | 02:29 AM
DONAIMIAN's Avatar
That iorn 408 starts off as a 6L iorn truck block.
