Driveability/Streetability w/ FM13 or G5X3
Car is an A4:
3:73's
Vig 3600
AFR 205's
CURRENTLY 224/228, but trying to deceide on FM113 or G5X3...
Driveability IS a factor, however car is 95% track car, 5% driven to & from the track..
Try an yank PT4000 - 4400 and go faster in the 60 ft and pick up a couple mph up top too
I dont think its worth the time or investement to change the cam when a better converter would give you a better gain
Tony Mamo said the FM 13 would work well with the heads too, but I'm not sure there will be that much of a difference going to a FM13 since I already am running a 224/228.
(The FM13 is 230/232).. I am on a LSA of 114 (A4)
Ellis
Your car makes great power right now. Enough to get ya into the high 10`s with the right converter and good traction.So to me its not worth the money to change cams and then have to retune .
I defintly woudnt go with the vig 3600. I can only tell you from experience that a PT yank or atleast a 4000ss will pull harder uptop than the vig 3600.
Ellis
car drives freakin fine. im 1% track 99% street. i drive the bitch 25 miles each way to work on days that arent shitty. i have a 3400 stall and its just fine with this cam.
3:73's
Vig 3600
AFR 205's that are already installed & milled to 62cc
A&A forged short block that has notched Diamond flat top pistons 2-3 cc...
You name the cam choice..
