402/TH400 cam grind?custom?who?help.
It's cam selection time for the new Texas Speed 402 short block.
It will be going into a 2000 WS6 with a TH400,4,000 stall & 4:10 gears.
The motor has MTI stage 2E heads,Comp roller rockers,SLP throttle body
Z06 intake,underdrive pulley & custom tune as per last motor.
I know I'll need new injectors & a retune,but Ive heard different information
on the cam size in the area of the effect the TH400 would have with the
different 1st gear vs a 4L80,TH350 or a 6 speed(which is coming out)
I will drive it on the street & the track,mostly street,I've driven rank big blocks,so I know it will idle like ***,however I just want to make sure the cam has enough low end torque to work with the TH400 gearing.
Ant suggestions?
Ant suggestions?
With a 4000 stall..... it won't matter much, as the motor won't really be down there. I'm running a 402/th400 setup, and with the loose converter I have in my car it's at about 2000 or more even just putting around... same 4.10 gearing too. That being said.. I'd go for something that's matched to the heads/rest of the setup more then worrying about the low end where the motor will rarely be.
I would do some research on the heads/cube combo and see what has worked. I like my cam/heads/cube combo but I asked the expert (at AFR) to order me the cam that would get what I wanted out of my combo. Basically I told Tony that I wanted a daily driver race car that idles nice (with extensive hours of tuning) but really moves out. See below for what he came up with. I like it.
Originally Posted by walker94z28
I have a 402 as well and mine has a Texas Giant cam. 1.48 is the best N/A 60 ft so far.
JUST WANT TO DO ENOUGH RESEARCH TO MAKE A GOOD DECISION.
THANSK FOR ALL THE INPUT.
