L92 aftermarket valvetrain?
Springs/retainers/keepers
Rocker arms
Valves
Nate
Why shouldn't I worry about running the stock rockers? What's the HS mod?
HS rockers=Harland sharp mod. If you pm Nate@Nasty Performance he can give you the full details on what he does to the rockers. I think his post name is NastyN8 on here.
Nate
V6 Bird, never thought about machining the heads for whatever valvespring or valve I wanted. I'm sure once they heads starte becoming available in a reworked version, they'll have upgraded valvetrain.
Dealerships say alot of things
Call Gene @ Fred Beans (gculley@fredbeans.com or 484.931.4800)- he says he has them in this post. -> http://forums.corvetteforum.com/show...4&postcount=31
from this thread ->http://forums.corvetteforum.com/show...1521569&page=2
So if the L92 head shares the same springs, retainers, and locks as the LS1, then any aftermarket LS1 valvespring package will work. Patriot recently released a new and improved dual gold spring kit that's even better than the old kit. So this may be a good option.
Then, sending the rockers (8-L92 intake rockers/8-LS1 exhaust rockers) to Harlan Sharp for rebuilds.
I think those 2 options would be a killer setup and affordable as well.
