Advantages on carburated
Old Nov 10, 2006 | 10:29 PM
03 BUSA's Avatar
Default Advantages on carburated
What are the advantages/disadvantages to going to carb setup? Car is not driven daily. I know I will lose traction control and such, but should be cheaper than a better intake and tuning for 427cu.
Old Nov 11, 2006 | 03:19 AM
pist0lpete's Avatar
I would say better intake flow especially for larger cubic inch setups. Slightly more power up top possibly when compared to a high flowing fuel injection setup. Disadvantages would include loss of throttle resonse slightly loss of part throttle performance driveability, problems cold weather starting, and loss of gas mileage.
Old Nov 11, 2006 | 05:22 AM
2002_Z28_Six_Speed's Avatar
Carb will require continous retuning to get it right each time you use it and rebuilds through the life of the car. Esp if you are going to store for long periods of time w/o using it. It is easy to tune a carb but you dont know the exact fuel ratio. Carbs are expensive and rebuilds are annoying.
Fuel injection is more precise and once it is together you never has to physically mess with it. All computer code. No choke to mess with. All you have to do is familarize yourself with programming it and you are so much better in the long run. If I set the fuel to XXXX at that cell and the idle is set to XXX I know it is always going to be that where with a carb turning screws isn't that accurate. Also, with EFI the computer can protect the engine where a carb setup can't reduce timing or cut the engine for a rev limiter.
I understand you have to get over the hurdles of tuning EFI but I really believe it is better.
Old Nov 11, 2006 | 09:32 AM
WizeAss's Avatar
so i guess he wasnt referring to a carb intake with welded injector bungs?
Old Nov 11, 2006 | 01:18 PM
03 BUSA's Avatar
Why, what do you got??
Old Nov 12, 2006 | 02:53 AM
Link please??
