New 402 install my tach doesnt work help !!!
Old Nov 14, 2006 | 05:47 PM
Mrbowtie26's Avatar
Originally Posted by Y2WS6KAH
I also recently installed a 402 and I too had the same problem with the tach and dummy me - had two plugs reversed. The cam sensor plugged into the MAP- Manifold Absolute Pressure Sensor and the MAP plugged into the new cam sensor extension harness. So then I switched them and it works ok now.
I wish that was my problem I would be happy lol.
Old Nov 15, 2006 | 03:48 PM
Mrbowtie26's Avatar
Ok, so I pulled sensor and checked it and looked into hole and saw I had the right sprocket, i cleaned a couple small things that was stuck onto the sensor off. Double checked wires and couldnt find anything else. Figured I'd put it back together and check everything again. started it and tach works now ....... I wonder if it was the couple small things stuck to the sensor ? I didnt clean sensor off when i put timing cover on , maybe it got stuff on it during shipping and I never seen it ? oh well now I gotta tune so it idles better with my cam in it. still idles rough barely stays going and runs a little rich.
Old Nov 15, 2006 | 07:38 PM
DrkPhx's Avatar
Glad to hear. Curious to know what these "small things" look like? Metal particles, gasket material?
Old Nov 15, 2006 | 07:45 PM
Mrbowtie26's Avatar
They must have been metal particles as they were sticking to the magnet. I believe they were on there when I installed the front cover, I should have checked it though before I installed it. Didn't think there would be a problem. Im gonna change and check the oil anyways so I'll just keep an eye on it and make sure theres no issues. Now to just get it to idle and run smooth with the cam in it. Anyone know what I have to adjust in ls1 edit for open loop idle ? as I think the main VE tables are used for that during closed loop unless I am mistaken.
