Heads/cam questions help needed
They are by RHS.
I am looking to get RHS™ PRO ELITE™ GM GEN III heads with .650" lift but am undecided on the cam. I want something streetable. Strip doesn't matter much.
Also, can someone explain why the 225cc won't fit a 5.7l LS1? They are both the same dimensions but different intake runners.
Now the cams:
Do I go with Comp Cams XR265HR 212/218 ~ 0.522”/0.050” 114 LSA (as they tested with the heads) or will a slightly more aggressive but still moderate cam such as Comp Cams XR269HR 216/220 ~.525/.532" 114 LSA net a little more power with the heads?
I am still learning the ins and outs of how heads/cams work together so any and all help is greatly appreciated.
My plans:
I will be running the car N/A for a year or so, eventually adding a Procharger DSC1 (possibly after next deployement). So, in short I need to get the right set of heads and cam on the first try. I can't afford to do head swaps every year or so.
Current exhuast mods:
Jet Hot headers (1 3/4"x3") with 3" ORY, 3" intermediate, 3" over axle and SLP 2.5" DCME (345hp package).
Current intake mods:
SLP CAI, Whisper CF lid, Holly Powershot filter, self descreened and ported MAF, SLP smooth bellow and self ported TB (I love the free mods).
Predator tuned and 160*stat
Edit: LS1 I assume? Wrong forum then. :o
The cams you listed are badly mismatched for those heads. They'll suffocate them. You'll want quite a bit more lift and a little more duration and it'll still be very streetable. You can always ask Bret to make you a cam.
If you are looking for the baddest heads on the market look no further than AFR 205's, TFS, or the TSP Terminators, all of which are greatly cheaper than the RHS offerings.
Your cam choices are all mismatched for any of those heads. Get a custom grind or at least into the 220's on both sides with a higher lift to take advantage of all that flow.
Actually just call TSP or TEA and give them a check and tell them what your goals are. They'll get a lot closer than you will.
Nate
Nate
+1 and that cam is so weak. You can go much larger and still keep it streetable. Talk to some of the site sponsors. They will help you out and won't just take your money. For head and cam I recommend Thunder Racing, hands down. Give Paul or David a call.
I wish the article from Chevy High Performance magazine was online. It was called Head Games. December 2006 issue page 48
They put out 529hp 488lbtq with 3" magnaflows, Fast intake, 78 mm tb, comp cams xr265ht .522/.529, 212/218 114* and RHS 210cc heads
Read through the dyno forum on here for a few weeks to get an idea of what combos put down the numbers. Better yet read the drag racing results section and see what heads get it done on the track. That is the true test.
Nate
