LS7 GM Intake vs. Sheet Metal?
Some have reported with a set of 39?cfm ported LS7 heads that a cleaned up Factor GM LS7 intake, the combo can flow in the neighborhood of 350cfm through the intake.
How much additional power would it make with a Sheet Metal intake that would not restrict the flow?
Also, not sure if the correct runner length Sheet metal intake could be made to fit under the cowl of the f-body.
Beck makes some real nice sheet metal intake that fit under the cowl of the f-body, but the runners are about 5 3/8 inch long, do you thing that this is a little short for a 427 LS7 style headed solid roller motor that would turn max 8,000rpm?
Bob
also, i'm not super wild about the idea as it would not be an optimal intake due to the hood/height issues, at least on a stock hood on a corvette.
Thats what I hear anyway..
huh? You cannot make blanket statements about sheet metal intakes..No 2 are the same..If the intake is designed right nothing will beat it.(Sheet metal that is)
Just like putting a cylender head on a stock motor that flowed 370 at 600, the peak numbers might look better but under the curve it will suffer.
A 408 is 62 cubic inch larger than a 346 or about 17% larger.
408 can make 510, 520, 530rwtq. 455 when doing right should be 10% greater than this or about 560,570,580rwtq.
I dont know a whole lot about the new LS7 intakes but I know a Fast 90/90 will kill over at about 6500 on a big cube mod effort NA street set up. I would think the complex engine management/fuel injection combined with the torque of the extra cubes there would be minimal drivability loss from the Carb style intake on a street/strip car?
I haven’t thought about the GM LS7 Carb intake, machine the injector bosses and get a 90 elbow and that might work.
Not sure if it will fit under my WS6 hood.
It would be n ice see some Dyno/Track comparisons, guess if I waited a year.
Thanks for all the info
Example...A cam shaft spend the least amount of time a peak lift so why concentrate all of the effort to maximize flow at peak lift? In a race only aplication where the engine will spends the majority of its time in exess of 7000RPM a manifold that makes best power in this erea "like the fabricated peice" might be the better option. I dont know of any fabricated intakes that arent designed to operate at extremely high RPMs. Other wise why would you spend the money to buy an intake that doesnt perform like one thats over ten times cheaper....because it looks good in the engine bay?
A properly fabricated sheet metal intake will outflow a composite and carb style manifold at every lift point. The only reason they lose lowend power is because they are a shorter runner. If you study anything on wave tuning you would see why this is so.
Also camshafts hit every lift point twice (except for obviously absolute max) so that pretty much kills your low lift theory. And camshaft size doesnt dictate where or if the manifold will make power.
I hope you are understanding what I am saying, because based on your statements you are misunderstanding the way an engine makes power.
Nate
