Is it safe to go .030 bore on a LS2?
Old Nov 17, 2006 | 12:14 PM
fastGBcamaro's Avatar
Default Is it safe to go .030 bore on a LS2?
Yes or no, I see that the recomended max bore appears to be .020 on some websites. If I do go .030 and something were to happen with the block and it would need to be honed, would I be screwed and be forced to either buy a new block or a new set of sleeves? What cubic inch would an LS2 be with a 4.1'' stroke and .020 bore be?
Old Nov 17, 2006 | 05:15 PM
Beast96Z's Avatar
You wouldn't be the first person to go 4.030" on a LS2 block. There are a few floating around. However, if you did need a rebuild, I'd say you'd be SOL on a bore/hone for reringing. The 4.020"/4.100" combo would net you 416 cubes. I highly doubt 2 cubes will make that much diffrence, and you'll have a extra .010" if you ever need it.
Old Nov 17, 2006 | 05:58 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
I know there are people going .030" over but GM recommend a max of .020"
Old Nov 17, 2006 | 09:36 PM
SLED28's Avatar
I am never a fan of taking a brand new block out to its limits for the reasons Beast96z mentioned.
Old Nov 18, 2006 | 03:12 AM
BIG BAD BLACKSS's Avatar
What about a 6.0 iron block. I know people are taking them to .030 to make 370s. Is that thier max?
Old Nov 18, 2006 | 08:29 AM
SLED28's Avatar
I have built many 4.060 truck blocks with no problems
Old Nov 18, 2006 | 03:46 PM
00 black ram air's Avatar
If you do it I have a set of pistons and rings for you depending on what your doing with it
https://ls1tech.com/forums/lsx-parts-sale/603399-diamond-pistons-diamond-pro-select-rings.html
Old Nov 18, 2006 | 09:58 PM
Randy WS6's Avatar
I have a .030"over LS2 and runs great,with 4.100"stroke ,6.125 rods = 418cid.
