Map sensor use with carb intake??
Old Nov 18, 2006 | 09:01 PM
03 BUSA's Avatar
Default Map sensor use with carb intake??
How are you guys incorporating the Map sensor, brake booster hose, hvac vacuum line to the carb style intakes? Also what fuel rails are most of you guys using? I would like to be able to connect to the factory quick connect supply line. Thanks for the help.
Old Nov 21, 2006 | 05:35 PM
03 BUSA's Avatar
Anyone?
Old Nov 21, 2006 | 09:18 PM
JBM's Avatar
JBM
interested as well.
Old Nov 21, 2006 | 09:29 PM
03 BUSA's Avatar
being told by Intake Elbows that there is 3/8 thick backing to the elbow to tap and drill fittings for the brake booster and HVAC vacuum lines. I am waiting to hear back on the map sensor because the LSX style map sensors are a push in style. Maybe could be drilled large enough to just push in?? Will let you know if I hear anymore.
Old Nov 22, 2006 | 12:12 PM
383ss's Avatar
the Vic Jr comes with a provision and bracket for the map sensor and has a hole for the brake booster.
