Ported L-92 Heads
Toss the OEM valvetrain and get what matches the camshaft. Plan on good parts to maintain valvetrain rigidity.
Here's the best part...this level of performance will easily be under $1k
-Geoff
-Geoff
Yes, I'm guessing these things will make big power with less duration than we normally see, especially with smaller cube motors. Especially since the ports are a little big anyways. Starting with a LS2 block is all you need to do. I have a feeling that the large valve for the bore and the large cross section normal rules that apply might not apply here with these heads. With these things 400 cube motors should be able to make power till 7000rpm without too much issue. These heads are just too dam good in terms of velocity profile AND chamber shape.
Bret
Bret
Quick question just how bad does an LS2 manifold flow? I've seen here that they don't flow very well but thats all relative right? I mean the LS6 flows better than the LS1 but the LS1 really doesn't flow that bad, does it?
I need to have this clarified if anybody has the patience and or time. Thanks
https://ls1tech.com/forums/generation-iv-internal-engine/565248-livernois-motorsports-tests-gm-l76-l92-carb-manifolds-gmhtp-magazine.html
As far as the GMHTP article I doubt it's going to tell us more than we already know.
The intake should flow more due to the 25% larger cross section of the intake over the LS6, if it flows half of that % gain more than the good LS6 stuff then we should see over 310cfm thru the manifold which would be a huge improvement.
The only thing that worries me about these castings is the large cross sectional area, but the valve area relative to the cubes on the 6.2L is right in line with the LS1 and LS6 so the port has to be proportional to the valve. That plus this is a much better port design.
Bret
