LS7 dry sump on a LS1?
LS7 crank is slightly longer for the dry sump, but you would need to put a 24x timing wheel on it to use your LS1 computer.
or get ahold of the crank that Katech is using in there 346 LS7 motor (no that one may be way to small on the stroke and turn your LS1 into a 302 or something smaller).
http://www.w2wpowertrain.com/pc-121-...-sump-kit.aspx
