Performance Manifolds for ls1 ls2
Old Nov 20, 2006 | 04:25 AM
hockos's Avatar
Default Performance Manifolds for ls1 ls2
Hi have a look at the performance manifolds at hocking racing shop, eigth throtle body kits for all ls1 ls2, great HP and Torque
Old Nov 20, 2006 | 07:29 AM
Z06PSI's Avatar
I'll be the first to ask........ Price...??????
Old Nov 20, 2006 | 08:17 AM
tmoneyr007's Avatar
I'm gonna guess ~ $6K
Old Nov 20, 2006 | 08:34 AM
Hennytime's Avatar
thats ******* awesome looking
Old Nov 22, 2006 | 10:24 PM
hockos's Avatar
Default hocking racing manifolds
on guys we are a race team that have built these manifolds for our race cars and we love doing it so we are not ever going to over price these kits, the ls1 kit is $3,600 USD and the ls2 drive by wire units are $4,239 USD delivered to your door. Also the guys from Efi Live have worked with us to develop the tuning side of the kit so no problems,
File Type: pdf
Old Nov 22, 2006 | 11:26 PM
Bink's Avatar
$4,239 USD - what does the kit include?? What do you have as air filters/cleaners?
Old Nov 22, 2006 | 11:32 PM
Ferocity02's Avatar
$Left ********
Old Nov 22, 2006 | 11:37 PM
Beast96Z's Avatar
You'll probablly have to work that out yourself. All models being diffrent, no engine bay will be the same. I'm having to build something for my Harrop now.
Old Nov 23, 2006 | 12:37 AM
Quickin's Avatar
Those prices are pretty ridiculous you know.
Have they been flow tested to see what the gain is over the ported LS6 intake and more importantly the LS7 intake?
ALSO, flow test numbers with the intake attached to the LS7 heads?
For that price they better allow the total potential of what the LS7 heads can flow (near 400cfm@.650).
Old Nov 23, 2006 | 05:03 AM
hockos's Avatar
Default you are looking at the wrong manifold maybe
I have been building engines for race cars and street for 30 years, You are compearing a single throttle manifold with a 8 throttle body kit and asking if they flow more, the guys that built the C5r race engine should have had you on the team, so they would had used the single throttle body manifold, look it is a fact that a metter amount of air and fuel into each port makes HP and Torque. race cars all over the world use this type of system it is not a new thing, and I have sold kits to many race teams, so ridiculous you say i have built manifolds that are $26,000 USD so I havent over priced these as you see, but you are able to make up your own mind and put it down before you ask for more details to get the facts right first. it is easy don't buy one just keep using the single throttle,
Old Nov 23, 2006 | 05:36 AM
ls1408cp's Avatar
do you have any dyno results that are normal. With a list of mods on each engine. I would like to see some back to back results I dont give a **** about torque.
Old Nov 23, 2006 | 07:19 AM
BlackHawk T/A's Avatar
Old Nov 23, 2006 | 09:41 AM
Beast96Z's Avatar
Originally Posted by Quickin
Those prices are pretty ridiculous you know..
It's the cheapest ITB on the market as of now...
Have they been flow tested to see what the gain is over the ported LS6 intake and more importantly the LS7 intake?..
It's an ITB, it should flow to the full potential of the head. Can't compare it to the LS7 because it isn't a LS7 style.
No point since it won't bolt up. It's a LS1/2/6 design.
The price is fair. With the Harrop coming it at nearly $5k, his price is almost back to the original" cost of the Harrop. Depending on the throttle blade size, I cant imagine the intake being a hinderence.
.[/QUOTE]
Old Nov 23, 2006 | 10:18 AM
SlickVert's Avatar
Do you make one that will fit a LS7 style head and fit under the cowl of a f-body.
Old Nov 23, 2006 | 03:26 PM
ls1408cp's Avatar
The price is fair if it makes more power over my ported victor. I would buy one if it could beat my victor by 40hp.
Old Nov 23, 2006 | 05:14 PM
cws T/A's Avatar
So if an engine currently produces 450 rwhp with a single blade like our crap were stuck with , how much more POWER do we get going to 8 individual throttlebody manifold ?
Old Nov 23, 2006 | 10:13 PM
Nate_Taufer's Avatar
Have you guys been living under a ******* rock? This is by no means the first ITB intake on the market. Do a little research and see that these are for the big boys. They cost a lot but you get what you pay for. A 244/250 on a 106 lsa would idle about the same as a 224/228 on a 112 with an ITB intake in a 346.
Nate
Old Nov 24, 2006 | 01:48 AM
ls1408cp's Avatar
Nate
what do you consider big boys? I would like you to find me some good info then. I dont care if it idles any better I would like my car to run na a little better.
Old Nov 24, 2006 | 04:29 AM
hockos's Avatar
Default Hocking Racing Shop Manifolds
hay guys take a brake for a second, yes the big guys do use then and it is a great way to gain torque and Hp, And Nate_Taufer is right the engines do run better straight away because of the metter amount of fuel and air, we have a 2" butterfly so you don't have to be worried about airflow, we run a big block manifold 572/ 615 / 427. to . anyway i will be posting Dyno runs and a complete price list and model list soon, one of your Forum guys are buying manifolds and is testing for me soon so we can get dyno runs with your fuels and mods, this photo is a four wheel drive we built the first 6 speed manual 427 GTO in OZ, it dynoed at 700HP at all the wheels, hope you like it and have a happy thanks giving and holiday,
Old Nov 24, 2006 | 03:08 PM
It would really depend on what your cars setup is to determine how much you would pick up. You would probably want to run a different cam to take advantage of each cylinder having its own atmosphere. You should probably pick up 40 hp over a fast intake. On a 408 even more so. I think I remember you having a vic jr setup, but you could get away with a ridiculous cam and pick up quite a bit if you have the RPM available.
Nate
