Lifters: Morel vs. GMPP
Old Nov 28, 2006 | 02:10 PM
Dragaholic's Avatar
9 Second Club NA
280Z28, those are the other ones that I'm referring to in this thread.
Morels vs. GM Performance Parts race lifters
Old Nov 28, 2006 | 02:22 PM
280Z28's Avatar
I'm probably using those for my build.
Old Nov 28, 2006 | 04:02 PM
ONEBADWS6's Avatar
I run my comp R's to 7500 for 2 years with no problems.
Old Nov 29, 2006 | 09:16 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What rpms do you plan to run?
My Comp lifters are holding 867rwhp and 7200 rpms. We'll see if they like 7500 rpms in 2007. If I have any problems I will go with the Morels.
Old Nov 29, 2006 | 11:23 AM
Dragaholic's Avatar
9 Second Club NA
I'm not sure. My old max effort cam only setup spun 7200 rpms, so I would guess somewhere around there, maybe a little more.
Old Nov 29, 2006 | 12:11 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
The way I look at it is, I had a '00 completely stock longblock (heads/bottom end) with the exception of a cam, valvetrain, oil pump, timing set, and rod bolts that spun 7200 rpms. That was using my factory '00 LS1 rocker arms and lifters. I figured if the lifters lived through those kind of rpms, why wouldn't the GMPP race lifters do so? I know that they were put in race Caddys, but as you mentioned, they did have a lightweight rotating assembly/valvetrain which makes a big difference. I plan on running right around the same rpm as I did with my old setup. Really, what I was looking for was people who are actually using the GMPP race lifters so that they can vouch for them. I already know the Morels are proven.
like i said i am running the gmpp lifters, and i spin it to 7200rpm
Old Nov 29, 2006 | 12:15 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
I'll be using a set of L92 heads and with the huge 2.16 intake valve, kinda scares me.
well in that case i would definitely go with the morals because you are going to need a fair amount of spring pressure to control that big valve at high rpm, and the moral are meant to handle that
