L92 head gaskets
Of course I've never had problems with Cometics either.
RUn the GM MLS 7.0 gaskets if your running a 4.060+ bore if you want somehting durable. If your running something smaller run the 6.0L truck
The 6.0L truck can be run on the L92s but does slightly shroud the head a wisker
Dave
http://www.sdpc2000.com/search.asp?s...2179&doquery=1
LS7 7.0L head gasket. Much cheaper, multi-layer, and should be perfect for my application. What do you think?
Let me give you an example, 6.0L gaskets are 4.070-4.080 depending on which type on a 4" bore leaving .070-.080 differential. Now take the 4.140 gasket -4.065 for an overbore of .075" or the same as stock 6.0l
. In my eyes, especially building a lot of boosted cars the GM MLS have been the most durable. The problem come is trying to get the right thickness or bore to suite peoples need. I personally design my motors/pistons etc around them. Look at Harlan and many other in the FI sections using GM MLS.Dave
Dave
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
