Precision Race Components Ported 6.2L Cylinder Heads Almost Ready!
Old 12-28-2006, 12:33 PM
  #141
ZLEEPER's Avatar
Jason said that he was hoping to have all the "tweaking" done by the end of the week. No further info. on the actual availability date yet.
Old 01-07-2007, 06:55 PM
  #142
dhdenney's Avatar
Anything new over a week later?
Old 01-08-2007, 01:47 AM
  #143
PowerShift408's Avatar
For God's sake give me an update! Blueballin the **** out of me...
Old 01-08-2007, 05:19 PM
  #144
00LS1SS's Avatar
Hmmmm
Old 01-08-2007, 06:26 PM
  #145
jeremym's Avatar
Any update?
Old 01-08-2007, 11:41 PM
  #146
LS2 Pontiac GTO's Avatar
Any idea on when A CNC L92 will be designed to work with the stock displacment LS2?
Old 01-09-2007, 07:25 AM
  #147
V6 Bird's Avatar
Maybe they didnt come out how they liked and are re-doing them. That'd be nice.
Old 01-09-2007, 09:00 AM
  #148
slt200mph's Avatar
From all the info that I have been able to find on these heads is that the intake side is pretty much perfect as cast and the exhaust side is the one that needs a little help..Chevy engineers really did thier home work on these heads before they went into production..now that things are getting back to normal after the holidays I would guess that we should see some CNC work finished and some heads ready for the consumer shortly .. even the guys at TSP have a "life" too ...
Old 01-09-2007, 08:53 PM
  #149
03 BUSA's Avatar
Been told that TSP is just waiting for the program to start cutting these things. They were supposed to have it last Wed. so that is the hold up. I already have a set of these ordered since the very beggining of Dec. So if you guys think it's killing you, I already paid for them.
Old 01-09-2007, 10:16 PM
  #150
Jon@Texas-Speed's Avatar
Sorry guys, I didn't realize this thread was even in here. (Been gone a few months) We are waiting on the program still. Hoping to have everything lined out VERY soon! Believe me we are trying to hurry! I'm wanting a set for my car too!
Old 01-10-2007, 07:26 AM
  #151
V6 Bird's Avatar
The digitizing of the port doesnt take that long. Its the actual port work and shaping things to show gains that you want. I know how difficult it is.
Old 01-10-2007, 08:22 AM
  #152
ScottyRocket's Avatar
Digitizing the ports does take that long when you rely on someone else doing it. The equipment isn't cheap, so a lot of places oursource the digitizing.
Old 01-12-2007, 09:54 AM
  #153
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Actually the digitizing did take a lot longer to do this time. The digitizing system was being relocated so it was down for sometime It's on the cnc machine right now though guys
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-12-2007, 10:54 AM
  #154
SDB
SDB's Avatar
what were the specs on the head as far as intake and exhaust flow #'s?
Thanks
SDB
Old 01-12-2007, 12:21 PM
  #155
Thanks
SDB
Ummm... post #1 maybe? That would be on the first page of the thread.
Old 01-12-2007, 02:14 PM
  #156
WizeAss's Avatar
Originally Posted by Jason 98 TA
We're nearly finished tweaking the 6.2l cnc program for you guys wanting to tryout the rectangle port heads on your strokers! We spent a lot of time developing the port & setting the valve height up for extra p/v while still flowing BIG AIR! These cylinder heads will be available with either stock 2.160"/1.59" valves, or the stage 2 2.180"/1.6x" valves. Either option will be shipping with our new valve spring option. With this setup I feel these heads will support about .630" lift or so. I'll test a few different setups to confirm this, but that's my guess...Compare these flow numbers to others flowed on much larger bores...
We all can assume the stock valves are for shortblocks with a 4.060 bore or smaller and the 2.18/1.60 valves are for engines with a 4.1 or larger bore. Have you considered the potential issues with PTV/valve shrouding by using the larger valved head on a 4.0 or 4.030 bore? It would be ill advised for someone to purchase these heads and not know what piston combination they can put on without potential failures. Just wonderin
Old 01-12-2007, 07:46 PM
  #157
dhdenney's Avatar
Kinda wondered this also.
Old 01-12-2007, 07:59 PM
  #158
LS1TECH Sponsor
Ryne @ CMS's Avatar
why dont you change your screenname to "Mr. 2cents", because on alot of threads you are giving just that....
Old 01-12-2007, 10:43 PM
  #159
LS1LT1CAM's Avatar
Waiting On The New Lsx Block. Have 3.62 Callies Crank, 6.125 Dyer's Rods And A Set Of L92 Bare Heads With Carbed Intake. Want To Know What Valves Using And What Lift And Rpm Spring Are Going To Be Good To 700 Lift, 7500 Rpm How Light Are Valve. What Rocker Arms Do You Suggest
Old 01-13-2007, 05:26 AM
  #160
dhdenney's Avatar
Jesel. Don't have anything else yet.
Quick Reply: Precision Race Components Ported 6.2L Cylinder Heads Almost Ready!
