ETP 4" Bore LS7 results and more testing at LGM
Old 11-30-2006, 09:55 PM
  #41
Bink's Avatar
Originally Posted by Beast96Z
Dropping the intake duration will reduce overlap, but you have to remember, some of these LS7 type cams have have 16-24 degree's of split in them. That'll put a good amount of overlap right back in.
So, would you open up (widen) the LSA to bring the overlap back down?? We don't need as much overlap effect on the intake .....right??
Thanks for the input guys...not trying to hijack...trying to understand what's going on.
Old 12-01-2006, 12:10 AM
  #42
SStrokerAce's Avatar
Hell guys nobody talked LSA or valve events here it was just durations.... which in reality isin't saying much.
Old 12-01-2006, 12:46 PM
  #43
Bink's Avatar
I thought they were referring to LG G5X-x cams.
Most of the LG cams are 110, 112 or 114 lsa aren't they?
Guess I don't know enough to ask the right questions- seriously, not try to be a smart ***.
Old 12-01-2006, 02:35 PM
  #44
Yeah got me as to what LSA... either. I know what I would run and change but not talking about that one.
Bret
Old 12-01-2006, 06:41 PM
  #45
Beast96Z's Avatar
Very true. Picking exaust numbers still has me as beflageled as some newbies.
Old 12-03-2006, 10:44 AM
  #46
firefighter's Avatar
So I went to the ET Performance site and well they aren't too good with the pics. I was wondering if we could get some pics of chambers and ports and also what kinda optins for valvetrain.
Old 12-03-2006, 11:53 AM
  #47
PREDATOR-Z's Avatar
Wrong Pat.... there is too much cam in there and those heads will most likely make that HP with much less duration. Too much cam and too much port will do this. You either A) reduce port size as seen with the AFR 205's or b) reduce the cam duration.
Bret
No, I understand my surprise when I got 32rwhp with my little 210/224 115+1. And that is with stock heads. I guess my madness fell in the right place.
Old 12-05-2006, 01:05 PM
  #48
Super Hulk Smash
JakeFusion's Avatar
I know the G7X3 is ground on a 118 LSA. And the split isn't as wide as you'd think. So, I'm not sure anyone quite knows what's optimal for the LS7 or its derivates just yet. I mean, LPE has a 242/248 on a 113 for the LS7.
Old 12-07-2006, 12:53 PM
  #49
Nobody ever said they were all playing with the same stuff either.
Bret
Old 12-16-2006, 07:52 PM
  #50
ATVracr's Avatar
I think the intake valve needs to be opened in a different spot for those big LS7 ports
GrannySShifting
Quick Reply: ETP 4" Bore LS7 results and more testing at LGM
