Which cam for a 403 LS2
Old Nov 30, 2006 | 11:28 AM
DoesSpeedTurnUon's Avatar
Default Which cam for a 403 LS2
Now alot of ya'll i know are going for peak numbers, and drag racing. I... am not. I autocross and i stay in 1st, 2nd, and 3rd MOST of the time, other than that i drive my car daily. I'm wanting to go with a 403, can anyone help me choose a good cam for this motor, that with an LS6 intake and ported 243 heads, that i can get 475-500hp out of?
Old Nov 30, 2006 | 12:23 PM
MSGHUFF's Avatar
232/236 112 works well for me and with the AFR heads the car is an awsome daily driver with gobs of low end TQ
Old Nov 30, 2006 | 12:29 PM
GTslOw's Avatar
check out the HPE S cam great sound great numbers super streetable its a 238/242 .606 .613 115lsa made 439rwhp 402rwtq on an 04 gto with heads this cam and bolt ons only no fast 90/90
Old Nov 30, 2006 | 12:34 PM
eric01ss's Avatar
maybe a g5x4 or the hpe s cam both good some were int eh 230/240 range on 114 or 115 would be good for u
Old Nov 30, 2006 | 02:15 PM
I'm thinking 113 - 114 lsa, and the .600+ lift would be ok.
MSGHuff, do you have sound clip?
Old Nov 30, 2006 | 03:29 PM
NEVRLIFT's Avatar
What heads are you planning on using? With the stroker motors, the narrower LSAs tend to work better. The 113-114s will feel kind of soft in a big cube LSx.
Old Nov 30, 2006 | 04:48 PM
I plan on running ported 243's from my LS6. They need a little work on them, so while they're off, might aswell have them done.
So are you saying a cam closer to a 112 would be better? or the other way and say a 115-116? I dont want a whimpy sounding stroker! lol
Old Nov 30, 2006 | 05:29 PM
98Z28CobraKiller's Avatar
Restricted User
The lower the lsa the lopier the sound.
Old Nov 30, 2006 | 06:53 PM
Yea, i know that much. I'm used to looking at cams for stock displacement LS1/6 motors... not a 403ci stroked LS2, so i'm not quite sure what to look for.
Old Nov 30, 2006 | 07:02 PM
GTslOw's Avatar
HPE uses the S cam in just about all of their big inch motors awesome cam will not be dissappointed. they did an 02 ws6 408 motr with afr 205 heads which is small for a 408 with the s-cam and mad 500rwhp and 488 rwtq.
Old Nov 30, 2006 | 07:05 PM
Quik's Avatar
try this one out 244/248 612/615 112+2 it was actually spec'd for a 408. its never used puleld it out cause i went with the L92s
GTslOw's Avatar
the s-cam is a 113 lsa not 115 as i stated earlier
Old Nov 30, 2006 | 07:19 PM
I'm talking to Quik about his right now, but that might be a good cam to look at, i'll check it out.
Old Nov 30, 2006 | 08:35 PM
Quik's Avatar
Old Nov 30, 2006 | 10:54 PM
MSGHUFF's Avatar
Sound clip and dyno sheet are here..https://ls1tech.com/forums/dynamometer-results-comparisons/560284-my-402-small-cam-afr205-results-long-post.html
Old Nov 30, 2006 | 11:48 PM
Bring the Noise's Avatar
Lunati Voodoo 60512 - 232/238@.050 (282/288@.006) .609"/.609" max lift 113 LSA runs about $300 from Summit, or Jeg's.
Old Nov 30, 2006 | 11:50 PM
what kinda power woul dthat make?
Old Dec 1, 2006 | 12:51 PM
GTslOw's Avatar
this cam is great for an ls1 ls2 but too small for a 402
Old Dec 1, 2006 | 01:26 PM
Yea, i was thinking the duration might be a little low compared to some of the others i've been told to go with.
Old Dec 1, 2006 | 01:32 PM
MSGHUFF's Avatar
Huh???? please explain your theory behind this?
