LS7 Intake "Hiss"
Old Dec 2, 2006 | 05:26 PM
mikey's Avatar
LS1TECH Sponsor
Default LS7 Intake "Hiss"
Hey guys, we just finished up a 427 LS2 with GM LS7 heads and intake. We hear an audible hiss on the right side or so it seams. The fuel trims look to be ok and we sprayed the area with no change. Has anyone else heard this noise? Sounds like a vacume leak but doesn't act like one.
Mike
Old Dec 2, 2006 | 07:05 PM
99Fbody99's Avatar
Remove the PVC hose and cap it, see if its gone. I use ls6 style valve in all installs now.
Dave
Old Dec 2, 2006 | 07:07 PM
mikey's Avatar
LS1TECH Sponsor
This has an LS2 style valley cover and does not use a PCV. We did disconnect and cap it with no change. The hiss seems to be coming from between the #6 and #8 injector but it's so hard to tell really.
Old Dec 3, 2006 | 10:58 AM
Louis's Avatar
Mikey, all of the C6Z stuff is quiet as can be. Perhaps it is on the underside of the port?
Old Dec 3, 2006 | 11:34 AM
Nate_Taufer's Avatar
Mikey, I have had this same problem on my car for quite a while. I suspect it to be a leaking manifold on the bottom of the intake/runner transition but I'm too lazy to fix it because it still runs fine. I would take the manifold off and look for any casting inconsistencies around the passenger side ports. Maybe you have a torn gasket? Hope this helps and good luck.
Nate
Old Dec 3, 2006 | 05:06 PM
mikey's Avatar
LS1TECH Sponsor
I took the manifold off today and can't see anything wrong. I'm sending it back to the dealer on exchange. Playing the probability game to see if another one does the same thing.
Old Dec 4, 2006 | 11:41 PM
John B's Avatar
Moderator
No hiss or issues with mine.
Old Dec 5, 2006 | 12:43 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
I'd check for a leak on the injector side. Not enough to blow fuel, but enough to make noise. Might check for a nicked injector o-ring.
