L92 Cam Guestimates & Opinions
L92 heads
L76 Intake
Kooks Longtubes
SD Tune
Non-Daily driver with weekend trips to the drag strip.
Non-valve spring killer
6500 rpm rev limiter
so......
the point of my post was to start a discussion. thats it.
Dont forget the size of the valve will act as though you have a lot more duration. Valve size is almost 10% larger. So maybe a 220 will act as a 240!
I think lift will be your friend and of course the all important overlap..
Then crutch that Exhast to compensate.
so what you're saying is that im irrational for going out and doing it myself?
Sometimes you have to listen carefully and trust your gut. I think it worked well for me. But to be honest, it could have bombed big time but I was willing to take one for the team going into unknown territory.
My $.02
My $.02
......Intake Duration - ID 288 236 163
....Exhaust Duration - ED 306 254 177
Lobe Center Angle - LSA 110 110 110
..Intake Centerline - ICL 110 110 110
...Intake Valve opens - IVO 34 8 -28.5 BTDC(- indicates ATDC)
...Intake Valve closes - IVC 74 48 11.5 ABDC
Exhaust Valve Opens - EVO 83 57 18.5 BBDC
Exhaust Valve Closes - EVC 43 17 -21.5 ATDC(- indicates BTDC)
...Exhaust Centerline - ECL 110 110 110
................... Overlap----- 77 25 -50 degrees
12:1 static compression will give approx 8.86:1 dynamic
just a best guess, but i am no cam designer
Brian
HiTech Motorsport
Brian
HiTech Motorsport
The overlap is also a good point, but on a Pro Stocker the overlap has a lot to do with durations of 275-285°@ .050" on the intake and 305° @ .050" on the exhaust..... Thats why they use a 118-122°LSA. A street car with a well tuned exhaust system is another deal all together and reguardless of how good the heads are or valves flow centerlines and overlap still have their place, just have to watch out WHERE that is with these cams.
Bret
