Stock crank bore size of an LS2
Old Dec 5, 2006 | 11:42 AM
DoesSpeedTurnUon's Avatar
Default Stock crank bore size of an LS2
Whats the stock crank bore size of an LS2? Is it 2.2500 or 2.12500? Thanks!
(i tried searching, but it wasn't working)
Old Dec 5, 2006 | 11:52 AM
Beast96Z's Avatar
I know all the aftermarket cranks are marketed at 2.100". Not sure of the exact stock size.
Old Dec 5, 2006 | 11:57 AM
Reason i'm asking is i'm thinking about buying these rods. I have a stock LS6 Crank i'm gonna put in an LS2 block.
Chevy LS1 / LS6 with 2.00 Journal. Complete with 7/16 WMC7 Bolts & Spec
Carrillo Part # C LS2<A76125
Center to Center: 6.1250"
PE Bore: .9280"
BE Bore: 2.1250" (Stock is 2.2500")
BE Thks: .9450"
Weight Total: 590 (447 Rotating) (143 Recpt.)
Old Dec 5, 2006 | 12:08 PM
Beast96Z's Avatar
The 2" Journal rod will not work with a stock crank. The 2" rod would only work with a aftermarket 2" crank, which only Callies makes at this point.
Old Dec 5, 2006 | 05:04 PM
DONAIMIAN's Avatar
Or you could get your stock crank turned down to a 2.0 journal, but I have no idea how much that cost.
