Potential problem with new build
Old Dec 4, 2006 | 09:47 PM
Stang's Bane's Avatar
Default Potential problem with new build
To make a long story short my pistons are .058 out of the hole. Evidently my block had been milled before. Anyway... my builder told me that I could just use a .072 gasket and that would still give me an acceptable c.r. My problem is I am thinking my ptv will be much smaller? Am I right here? I plan on running ~240 intake x ~252 exhaust cam. Should this fit with an unmilled set of LS7 heads? If I get a valve job on them will that give me more valve drop? Oh yeah, my pistons are -7cc diamonds. The valve cuts are 15 degree though. I probably need to get that recut huh? Any help would be greatly appreciated.
Old Dec 4, 2006 | 10:01 PM
DrkPhx's Avatar
Wow. Are you positive it's .058 out of the hole? Most LSX shortblock assemblies have the piston above the deck, but not that much.
Old Dec 4, 2006 | 10:06 PM
That is what he told me. i know the norm is .007-.012. Like I said evidently the block had been decked before.
Old Dec 5, 2006 | 05:48 PM
P Mack's Avatar
I would be more worried about the pistons hitting the heads.
Old Dec 5, 2006 | 06:21 PM
He told me by using a .072 gasket that would keep that problem away.
Old Dec 5, 2006 | 07:30 PM
JakeFusion's Avatar
Super Hulk Smash
That's only like .014" quench area, which is extremely shallow. Most people will recommend no less than .028" for a street LS1 and you're at half that. Hmm...
Old Dec 5, 2006 | 08:50 PM
99Fbody99's Avatar
Wow..No way the block was milled down that far.
A more likely senario is the wrong rod length/piston pin height combination.
better check the pin height info on the piston box, measure the pin height on the piston. Then do the rod info, I think the answer will be found.
Dave
Old Dec 5, 2006 | 10:34 PM
The shortblock is put together and he told me I wouldn't have any problems as long as I used a thicker gasket and used a bigger chamber on the heads. By the way how thick can cometic make gaskets before they become a problem?
Old Dec 5, 2006 | 11:30 PM
TheBlurLS1's Avatar
That's what she said...
That's pretty close. Rod/pistons are going to grow at temp and you might have some real problems.
Old Dec 6, 2006 | 01:39 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
4.125" Stroke Crank with pistons for a 4" stroke crank would do that also.
Old Dec 6, 2006 | 08:44 AM
Default Update!!!
Just got off the phone with Joe. Good news!! The pistons are only out of the hole .030. Much, much better.Now I can run a crazy *** huge bitch of a cam and still have decent Ptv. Even with a 70 cc head and a .072 gasket my compression will still be over 11-1. God, I feel so much better!!
