Best place for LS1-LS2 conversion stuff
Old Dec 6, 2006 | 02:07 AM
DoesSpeedTurnUon's Avatar
Default Best place for LS1-LS2 conversion stuff
Does anyone offer a whole kit?! front plate, rear plate, valley plate and cam and knock sensor harness? Am i missing anything out of that?
Old Dec 6, 2006 | 04:39 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I know speartech does harnesses and provides electronic parts. Try giving them a call. They're a sponsor.
Old Dec 6, 2006 | 05:00 PM
Beast96Z's Avatar
I got mine from SDPC. www.SDPC2000.com Full kit for $289 I believe. Comes with everything needed.
Old Dec 6, 2006 | 05:02 PM
Does anyone know if the oil pan has to be clearanced if i'm putting an LS2 block in my C5 with a LS6 crank?
Old Dec 6, 2006 | 05:05 PM
looking for it, but can't find it!
Old Dec 6, 2006 | 05:11 PM
Dragaholic's Avatar
9 Second Club NA
Wow, I'm surprised no one has hammered you for all the threads you've created with questions that have been answered numerous times before. It would be different if you were a newbie, but it shows that you've been here since '04. I know I'm given a hard time and I'll admit, I ask a lot of questions. Search is your friend.
Anyhow, Speartech, Katech, Scoggin Dickey, etc. all have adapter kits. If you can't find them on the sites, search here on the board, or give them a call. They'll take care of you.
Old Dec 6, 2006 | 05:13 PM
Dragaholic's Avatar
9 Second Club NA
By the way, the kit Beast96Z is referring to is:
LS2CK-2
Timing cover w/cam sensor, valley cover, lifter trays, crank key, cam/knock sensor harness, timing chain damper, timing set, etc.
Old Dec 6, 2006 | 05:14 PM
I must be lucky I do apologize. But, in my defense, and i'm sure others know this aswell... That search button up there, doesn't always work
Old Dec 6, 2006 | 05:16 PM
LS2CK-2
Well... actually, thats not pulling up anything.
Old Dec 6, 2006 | 05:21 PM
Dragaholic's Avatar
9 Second Club NA
I wouldn't say lucky, I just have a bad past that's all. The search is down at the moment, which is why I posted the part number for you including the parts it comes with.
The part number I posted isn't going to be on SDPC's website. Its a kit that was put together by Brian, not something that GM offers. You can't beat it.
Old Dec 6, 2006 | 05:27 PM
So where can I find it? I appreciate everything! With all this L92 talk, the LS2 threads have disappeared.
Old Dec 6, 2006 | 05:29 PM
Dragaholic's Avatar
9 Second Club NA
Again, the kit was put together by Brian. He works for SDPC. Its not something GM put together, so its not going to have a GM part number. The part number I posted is SDPC's unique part number, but it won't pull up if you enter it in their site. Trust me, its the kit you want. It has everything you need. Its cheaper than buying all the parts individually.
Old Dec 6, 2006 | 05:33 PM
Didn't realize Brian worked for SDPC. I'll give him a hollar.
Old Dec 6, 2006 | 07:51 PM
Beast96Z's Avatar
You don't even have to talk to Brian. He can be hard to get ahold of sometimes. Just call the number on their website and give them that part number.
