Solid LS2 w/ TSP L92 and 11.5:1
LS2 short block w/ better rods
TSP L92 heads milled/gasket combo to yield 11.5:1 static if possiable
Solid Roller Lifters
I am wanting you imput about a manifold and cam selection. I am wanting to run the LS7 manifold. Would the L76 be better for me? Also any thoughts on cam selection...I defently want to stay with a solid lifter. Any overall thought/comments (other than I am sticking a LS motor in a german car)?
It's going in a '98 BMW M3 and will weigh about 3150 lbs with the LS2 and T56. I am needing some input about the motor b/c I am not a GM guru. I only drive this car for fun...but want it to be streetable. Since the car is fairly light I am not too conserned with low end torque, but do want it to scream up top! I want a redline of 7000+ also.
The L92 setup isn't truly tested yet (dyno/track comparisons). I would sit back until the dust settles.
Currently the LS7 intake outflows the FAST 90 intake (this hits a roadblock in flow at around 6600rpm). The LS7 will flow well beyond 7K; however it needs LS7 heads.... and namely a 4.125" bore (the LS2/L92 block aren't big enuf). You can get some custom ETP LS7 heads that work with this block though (plan on waiting a while).
The intake for the L92 heads.... the verdict isn't really in whether it kicks *** over the FAST 90 or not.
This type of powerplant in your BMW should rip. Even with a big cam that may soften the bottom end power... the car will move along nicely. I have this style cam with AFR 205 heads (233/239 .600/.603 112LSA cam) and rev it to 7100rpm on a stock LS1 shortblock (with upgraded rod bolts).
It boils down to what your budget is. A 402/416 based stroker setup will be about $4-6K cheaper than building a resleeved LS2 427 or LS7 427. Which makes maybe 30-40rwhp more.
Run as much compression as you can for the gas you plan to run.
Power is power whether it is at 6500 RPM or 7500RPM.
If you really want a spinner motor check out the sneak attack 5.7 on Katech's web page. (Sponsor section on the right----->)
I think it goes to 8500RPM. It is a large bore short stroke motor and can rev to the moon.
I'm planning on putting a 335/18 out back to handle the power a built LS7 can generate (550-575rwhp) on my RX-7. You will need something similar with 500rwhp+ bottom line.
What gear ratios are available for the M3 out back in the diff? Messing around with that may be able to lessen the torque multiplication and help put the power down.
If you really want to spin it to 7500 often plan on breaking some parts. RPM's kills motors bottom line. You will be going thru valvesprings often as well.
My vote for you would be Katech's 5.7L I bet that thing is a freaking screamer!
