fitting Fuel rail, injectors, and TB for L92
I also have a set of billet fuel rails designed for LS1. Will these work? How does one mount aftermarket fuel rails?
What type of injectors/o-rings will work?
What TB- will a stock LS TB fit?
wrong l76 is the car manifold which is lower profile, l92 is the truck manifold
Assuming you have the L76 car intake, you'll need the same stuff that an LS2 uses. You'll need fuel rails for an LS2, and injectors or o-rings for an LS2. There's a lot of ways to go with the fuel system. You'll need a 90mm TB for this intake, as well.
The LS7 injectors that come with the kit mentioned in the thread are interchangeable with LS2 injectors.
So, the answer is yes, LS2 stuff works on the L76. I've been wanting to run this stuff on the LS2 in my GTO. I'm just waiting for the aftermarket to catch up to the L92 stuff.
Injectors with LS2 style O-rings will work. (Although most injectors are basically designed the same way- you just need a different O-ring at the intake side. You need to pick the flow rate and impedance)
What is the difference between LS2 fuel rails and LS1/LS6 rails? The reason I am asking is that I have a racing fuel rail designed for LS1.
You can cut the crossover and inset hose or use aftermarket rails, no problem.
