Warhawk LS1 Numbers
Old Jan 5, 2007 | 02:13 PM
MerlinPro's Avatar
Collections Removal
Default Warhawk LS1 Numbers
Tested on SuperFlow 1030-28", no pipe, straight valves, bowl blend no deeper than 1/2" in. As-cast heads.
Intake: Exhaust:
.200 - 134.0 108.3
.300 - 196.9 152.3
.400 - 241.7 178.7
.500 - 274.8 192.1
.600 - 295.3 197.8
.700 - 293.3 199.9
Old Jan 6, 2007 | 09:04 AM
fuelinjected 427's Avatar
Intake: Exhaust:
.200 - 134.0 108.3
.300 - 196.9 152.3
.400 - 241.7 178.7
.500 - 274.8 192.1
.600 - 295.3 197.8
.700 - 293.3 199.9
Is that good ????????
Old Jan 6, 2007 | 10:00 AM
V6 Bird's Avatar
not really considering these are not box stock and the bowl is blended. On top of that they back up...
Old Jan 6, 2007 | 10:46 AM
Richard@WCCH's Avatar
Not bad considering the straight valves. Probably missed it in a previous thread, but what are the runner volumes?
Richard
Old Jan 13, 2007 | 10:11 PM
Cliff's Avatar
What are the valves sizes and runner volume? These numbers are weak considering they are after market heads. Do you know the deck thickness? I hope they have a lot of room to be ported.
Old Jan 13, 2007 | 10:41 PM
WizeAss's Avatar
I assume they are backing up after .670lift...... if they are as cast, not bad... probably get a porter to add another 30cfm, otherwise I am not too impressed....... get some more info on em. Runner volume?
Old Jan 14, 2007 | 10:09 AM
V6 Bird's Avatar
Nah...They start at .600 thats why you dont see a .650 just straight .700. If they dont then they have something to prove and will post it up. It could be a simple valve job away from not backing up.
Old Jan 15, 2007 | 03:26 PM
MerlinPro's Avatar
Collections Removal
Technical Specifications
Material: 355-T6 alloy high density aluminum (.600" thick deck)
Valve Seats: Steel intake, hardened steel exhaust
Valve Guides: Bronze
Valve Spring Seats: Machined for 1.550" springs
Intake Valve Size: 2.080" on 220cc head"
Exhaust Valve Size: 1.600" (all stems are 5/16")
Valve Angle: 15° (same as rocker arm attachment)
Intake Runners: 220cc
Combustion Chambers: Choice of 64cc or 72cc
Valve Cover Rails: Raised .300" to clear aftermarket rockers
Assemblies: Choice of 3 spring/valve packages (plus bare heads)
Old Jan 15, 2007 | 05:21 PM
V6 Bird's Avatar
Pretty good size valve on those things for that type of number...Could be a valve job away from making some serious numbers.
