Idle video - LS7 with 40 deg. overlap @ .050
Originally Posted by Billiumss
Sounds great!!
Any more specs on the car? What Cat Back are you running?
https://ls1tech.com/forums/generation-iv-internal-engine/496186-introducing-world-s-first-ls7-f-body.html
Originally Posted by DoesSpeedTurnUon
Jason, what hood is on that Z06 in the background?! Does anyone make one for a C5?
Yes
http://www.acproducts.us
Originally Posted by Katech
a big one
how big?? .650's and 260's?? or solid roller setup?? Just curious... it sounds mean...... I am thinking I want something close but not quite that crazy!
How did you decide on an idle rpm? Would it idle any lower than 1100 or is that the minimum? The reason I ask is my 427 will have 42.5 degrees of overlap and i was going to try for a lower idle if it would run. Hoping for around 800 or so if possible. Trying to get more of a lope. However, yours sounds pretty badass at 1100. Thanks for any info you can provide.
