L92 heads on LQ4 how much compression?
Old Jan 9, 2007 | 09:54 PM
SUTTERERMAN85's Avatar
Default L92 heads on LQ4 how much compression?
ok i have an LQ4 block with pistons that are dished. stock with 72cc they are around 9.5:1 correct? if i use these pistons how much should i mill the heads which are 69cc stock and how thick of a 4.065" gasket should i use and fit up with the intake correctly? how many cc are the dished pistons? i am trying to figure up on the spread sheet but i am not sure what half of the #'s on there are. trying to get to at least 10.2-10.5:1 if i can. thanks for the help
Nick
Old Jan 10, 2007 | 09:57 AM
RWC's Avatar
RWC
Based on factory LQ4 compression being 9.4, I get 10.4 with a 63cc chamber using a .054 gasket and 65cc using a .040 gasket. Mill about .006 per cc to reduce chamber size. Dish seems to be around 7 cc best as I can tell. If you have Excell I will send you the spreadsheet to play with.
Ron
Old Jan 10, 2007 | 10:19 AM
well i can get a set of LQ4 style pistons for about $200 that are in a 4.030 bore. so if i could make them work its a bit cheaper. but dont know if it is really worth it. also i dont want to have to fly cut and am not sure if the diamonds valve reliefs in the flat tops are large enough for the l92 intake valve. BTW i have the spreadsheet off of here. thanks for the help
Old Jan 10, 2007 | 10:41 AM
RWC's Avatar
RWC
Those pistons should handle a decent size cam and be ok. What size cam and application is this engine for?
Old Jan 10, 2007 | 12:36 PM
370 with possibly a 240 246 112lsa
Old Jan 10, 2007 | 02:42 PM
RWC's Avatar
RWC
I think you need to check further to make sure with a cam that size. Good luck with your project.
Old Jan 10, 2007 | 03:18 PM
thats what i was thinking.
