Crankshaft Ls1 4" for LS2
Beside me question: possible use the crankshaft LS1 4" for Ls2 C6 05?
After all there another 58 reluctor wheel. Will it is correct to work crank sensor?
There is experience who answer.
So to answer the original question. No, the 4" ls1 crank will not work in a LS2 C6 unless you change the reluctor wheel to a 58x.
You can order a shortblock with either crank sensor but you will need to let the vendor/sponsor/builder know when you order the motor which timing wheel you are going to need.
