Help Please. Crank gear.(w/pic)
I am building a 402 and I am stuck with the crank gear. I am using the roller set that came with it from TSP. My crank is grooved and my crank gear is grooved, but is there a little piece of metal that holds the two together? The roller set doesn't have this piece and the stock gm crank gear doesn't have it either.
Looks like you need a woodruff key. Check this link:
http://en.wikipedia.org/wiki/Milling_cutter
Scroll down to the bottom, you'll see what they look like, just a little semi-circle. Pretty common, you'll just need to get one the right size.
