700hp n/a...how can it be done?
Will the stock L92 rockers handle 7000+ rpms and high spring pressures even with the harland sharp bearings?
or heavily ported and worked L92's?
4.25 bore and 4 in. stroke would bring you to 454 ci,
seems it will be easier to make 700 hp with a 454 instead of a 427
on pump gas, or even push the bore on the LSx to a 4.28 with the same stroke to build a 460 ci engine,
just my thoughts, cant wait for that block to be released
gl
gl
I agree 1000% and that is EXAXCTLY what I plan on doing!!
No, from what Ive been told. I wanted to run the L92 heads but I wont pay $1625 for Jesels for a car thats being built for fun.
W2W, SDPC and a friend who works for the GM performance race shop in Wixom told me not to run the stockers with 200+psi on the seat and 700+open.
If someone is doing this please, let me know.
gl
-Geoff
We are not using either. We use a custom filter that you have to get from CV Products. They are $54.87 each and hold 1.5 quarts. It is a custom filter for there remote filter relocater.
Thanks,
Amber
How do you think a ported LS6 Pump do reving up to around 8400 rpm or so with a stock pan? Just curious, ran into this thread while doing reasearch on my new to be solid roller set up.
And 700 flywheel h/p N/A on pump gas with 427 ci now a days, I don't see a problem with the heads out now. Hell I've got ported ls6 heads that flow 317 to 320 cfm at 700 and I made 630 rwhp granted on 110 octane ,but still the heads are awesome today. I can't wait to try some of these new heads out!
peace
Bad *** f-body my friend I love it and INCREDIBLE N/A times. How many cubes you putting out and what bore size are you running on your 6 liter motor, 4.060?
What compression is that bad boy making 13.5 to 1?
We make 615 (at the wheels) plus on more than a few LS7s on pump, and those are street cars
Its 4.030 bore and 15 to 1
left, will .030 more really make that much of a diff.,? on that particular block?
it is also advertised that the material used is also much more harder than the iron they use for convetional 6.0 blocks. i would think it would not affect it too much, for N/A 7000 RPM engine.
opinions?
Bret
Most of you guys keep forgetting we were turning my stock bottom end car 8200rpm's. It had between 400-600 passes when we pulled it apart to put the big inch engine in. We had several engine builders take a look at it and again no issues with oiling and we were advised that keeping this a wet sump would be just fine. I think most of the guys we asked have been in the engine building business for 25 plus years. Did you know that SBC's turned 9000rpms for years with a stock wet sump? Nascar was primarily a wet sump setup until the late 70's when they went to a dry sump setup. Just because some people can't keep them together doesn't mean in 100 passes we will have issues. We put about 1 year into this build doing research with both prostock guys we know, engine builders we know and so on. We built this thing to last so it does not have to be torn down. I will let you know in 150 passes if I have to tear it down but we don't think we will ever have an issue. It is more bearing clearance issues than anything. We now alot of SCCA guys turning in the low 8000rpms in the road racing because there class does not allow wet sumps.
Thanks,
Amber
T56Rebuilds.com
What Oil are you running?
Congrat, keep up the good work and record setting set-ups
Bob
