700hp n/a...how can it be done?
Old Jan 20, 2007 | 11:43 PM
  #61
1fstGM's Avatar
Restricted User
Originally Posted by TOSTO RACING
I have the 4.125 stroke in my motor with the 6.0 block. Also STOCK oiling system in my car its been 8200 rpm for 3 years no signs of anything going wrong. I beat the **** out of this motor and go through the traps and 8200 to 8300 everytime. I'm sure a dry sump is better ,but I haven't gone to one yet.
And 700 flywheel h/p N/A on pump gas with 427 ci now a days, I don't see a problem with the heads out now. Hell I've got ported ls6 heads that flow 317 to 320 cfm at 700 and I made 630 rwhp granted on 110 octane ,but still the heads are awesome today. I can't wait to try some of these new heads out!
What Oil.
Old Jan 21, 2007 | 07:05 AM
  #62
TOSTO RACING's Avatar
20w50 castrol.
Old Jan 21, 2007 | 11:47 AM
  #63
ls1 joe's Avatar
Slickvert I run royal purple racing 21 which is like 0w 20
Old Jan 23, 2007 | 09:47 PM
  #64
Trail 70's Avatar
Here is some real info. 427 4.125 stroke, tried 5 cams 11.7 to 12.3 comp.
3 intakes and 2 diff. headers. with ls1 heads it made 647hp. 600tq. with an hyd. cam for the street. Now with l92 and custom sheet medal intake after trying 4 cams and 2 diff. headers it did 660hp 570tq. This is at 7000rpms
for the street. These l92 like a very large header.
Old Jan 24, 2007 | 12:33 PM
  #65
Trail 70's Avatar
new numbers, changed cam timing and now 670hp. 570tq. Had ls7 heads and hogan intake on a diff. engine and that engine made less power then mine, with l92 and tpis intake.
Old Jan 24, 2007 | 01:06 PM
  #66
Old SStroker's Avatar
Originally Posted by Louis
It can be done on a hydraulic roller, on pump gas. Think outside of the box and make sure every detail is in order and no expense spared.
We make 615 (at the wheels) plus on more than a few LS7s on pump, and those are street cars
Look at BMEP (Brake Mean Effective Pressure) @ hp peak rpm. It's the "great equalizer" or a good way to judge any size engine's ability to make power. A good pump gas 396 LT1 with GREAT heads can make 600 fwhp ~6300-6500 rpm with a very driveable HR cam. That's a BMEP of ~185-190 psi.
700 fwhp from a 427 @ 7000 is a BMEP of 185 psi. At 7500 rpm, 700 hp is a BMEP is under 175 psi. Yes, as rpm rises it's tougher to get the BMEP, but a BMEP of 180-185 psi in the low 7's should be quite doable with 427 cubes, as Louis said. Just get everything right!
Old Jan 25, 2007 | 07:27 AM
  #67
1BADWS6@STENOD's Avatar
What kind and size headers did you use? What are you using now?
Old Jan 26, 2007 | 01:22 PM
  #68
Trail 70's Avatar
1badws6, started out with a 1-3/4 header then went to a 1-7/8 header and we picked up 20hp and were able to go from 30 to 34 deg. of timing. We think that a 2 in. would be better. TPIS found that the cam liked -5 deg. of timing. Hopes this helps..
Old Jan 27, 2007 | 09:53 PM
  #69
V6 Bird's Avatar
Here guys check this out. We are making 682 with 372 cubic inches right now. A few more tweaks on jetting and it should make the 700 we were gunning for. Pretty simple setup. Just very good work on intake and heads to get it there with a guy that knows how to spec a cam for the needs.
https://ls1tech.com/forums/dynamometer-results-comparisons/647910-372-preliminary-results.html
Old Jan 27, 2007 | 11:22 PM
  #70
black_knight's Avatar
Originally Posted by landstuhltaylor
big difference between flywheel and rwhp
Okay, 70 posts in and still no word on whether this was rwhp or flywheel... and yet everyone jumped the gun and answered anyway...
greaaaaaat...
