LS2 CKP System Variation Learn Procedure
Old Jan 21, 2007 | 11:21 AM
LS2GTM's Avatar
Default LS2 CKP System Variation Learn Procedure
I have a LS2 crate motor in a Factory Five GTM that I can not get the CKP system Variation Learn Procedure to run. I am using a Tech II scan tool to run the test but all I get from the tool is "condition not correct" Anyone have any knowledge on what conditions the tool checks for before running the procedure? ECM is programed as a 2005 Corvette and modified with LS2EDIT.
Old Jan 21, 2007 | 05:37 PM
SLowETz's Avatar
Tried replacing the CPS? Had the same problem on an '02 ls6 and finally replaced the sensor and the relearn took.
If nobody else chimes in, contact Mike@Vengeance >>>>>>>>>>>>>>>>>
