Offset SBC Rods in an LS2?
Old Jan 21, 2007 | 08:46 PM
StingrayCrazy's Avatar
Default Offset SBC Rods in an LS2?
Can I use Gen-I rods in a LS2? Any issues with the centerline offset? Anybody using them now? Just checking before I spend money.
Thanks Frank
Old Jan 21, 2007 | 09:33 PM
ChucksZ06's Avatar
yes you can. I have without issues. If the engine is going to be driven 100,000 miles I would use the ls1 specific rods but for performance I would not worrry.
Old Jan 21, 2007 | 09:42 PM
rons 00z's Avatar
does it matter? as long as the rod journal, wrist pin, length works for your application whats the differance?
Old Jan 21, 2007 | 09:53 PM
Thanks Chuck...
Looking for a 6.200" Rods. Limited choice with on-center LSX's but the Gen-I's open many possibilities... Just wanting to make sure there was no known issues with using Gen-I rods in the LS2 block.
Old Jan 22, 2007 | 01:27 AM
racer7088's Avatar
It depends like always. Many normal SBC rods will not work with certain pistons and will with others.
Old Jan 22, 2007 | 01:28 AM
racer7088's Avatar
Question
What is the application?
Originally Posted by StingrayCrazy
Thanks Chuck...Looking for a 6.200" Rods. Limited choice with on-center LSX's but the Gen-I's open many possibilities... Just wanting to make sure there was no known issues with using Gen-I rods in the LS2 block.
Old Jan 22, 2007 | 01:25 PM
Street Strip, Turbocharged (15 pounds or less) 6.0L Iron Block 3.622” stroke with 6.200" Rods and 1.215" CH pistons = 0.004" down the hole on a 9.230" deck. 9.5:1 compression ratio with L92/L76 up top Comp XER281HR 232/236 .595/.598 on a 112 LSA.
Frank
Old Jan 22, 2007 | 02:42 PM
96 Comp T/A's Avatar
FYI, You can run Eagle 6.300 SBC rods with an off the shelf (402-408 stroker) piston. You can come up with these with just about any dish size you want. I used Diamond -15cc dish in mine, they ended up .005 in the hole with no decking and my SCR is 8.75 with a 72 cc head and .040 cometics.
Old Jan 22, 2007 | 03:16 PM
racer7088's Avatar
Arrow
Who's pistons? The pin boss spacing will tell whether you can run those rods or not and the rods pin end width.
Frank
Old Jan 22, 2007 | 11:20 PM
They are custom flattops that were made for another build but were not used. They have standard SBC pin boss spacing. What I was most concerned with was the SBC con rod bearings on the Gen-III journal not matching. I called Eagle and Crower which both backed up what has been said here. The Gen-I and Gen-III share the same rod journal dimensions and there are no issues running off set rods on a Gen-III so long as you have the clearance between the pin boss to keep true vertical rod alignment under the piston.
Thanks Frank
Old Jan 23, 2007 | 02:22 AM
racer7088's Avatar
Arrow
Thanks Frank
Yep you can't run the offset SBC rods in an LS1 engine that has narrow inboard pin boss pistons witha 1.060 top.
