L92 heads on LQ9??
Old Sep 26, 2007 | 10:55 AM
speedshifter's Avatar
Looking to throw the L92 heads on my Procharged LQ4 in my '01 Denali. So far, I'm going to need the L92 heads, LQ4 head gaskets, L92 intake gaskets, L92 intake, larger cable TB?, Katech fuel rail spacers.
Anything else I'm missing?
Old Sep 26, 2007 | 02:39 PM
97F1R408's Avatar
Originally Posted by Billiumss
With everything else being equals beside the exhaust duration, wouldn't you think that if you go with too much exhaust duration you'll start to loose low end torque?
If I did this combo, this would be on my daily driven truck, that's why I'm thinking on the smaller side.
Will the new truck intake (L92) work on the LQ9 with L92 heads? Just wondering if the fuel rail, injectors, TB , etc will bolt up to the L92.
If you are looking for the truck manifold for the l92 heads I have one with the gaskets that come seperate. When installing I didnt really come across to many of the intake parts that would make a direct fit and the fuel rails for an 07 vehicle wernt available at the time of me doing this so I went l76 and used 97 vette rails because the truck was return style. I used a vette water pump and put an idler pulley right under the truck alt. and rerouted the belt. all is fine now. if you want the manifold $175 I believe it was 260 plus the gaskets.
Old Sep 26, 2007 | 02:50 PM
Thanks for the info! I think I'll just use my stock rail with the katech adapters for the newer intakes.
Thanks for the offer on your intake, but I work for a dealer so a new one costs me $150.
