Stock Crank hp?
Old Feb 1, 2007 | 02:12 PM
Gordon0652's Avatar
Default Stock Crank hp?
What is most LSx Cranks good for/ safely good for? hp? at the crank.
Old Feb 1, 2007 | 02:29 PM
Stang's Bane's Avatar
There have been several well over a 1K. As far as I know, one has never failed from too much power, I could be wrong though!!
Old Feb 1, 2007 | 02:34 PM
2000LS1TA's Avatar
I have heard that they are good up to 750 RWHP
Old Feb 1, 2007 | 06:04 PM
Gordon0652's Avatar
ok, thanks!
Old Feb 2, 2007 | 01:51 AM
Top Secret's Avatar
I've read in a book that a SAFE rwhp is 600. So probably 750 at the crank or so. Of course, there are those that would say otherwise. =)
Old Feb 2, 2007 | 01:36 PM
Karlo's Avatar
Default 500hp
This Book Tells me 500 hp max for a stock crank.
Old Feb 2, 2007 | 01:40 PM
gnx7's Avatar
The number of stock LS1 crankshaft related failures can be counted on one hand. They are stout even though not a forged unit. With rolled fillets on the main journals that helps to strengthen them... having 6 bolt main caps is another bonus.
How much power do you want to make and how do you propose to get there? ie n/a, nitrous, force induction....
Forged cranks are only around $600-750.... so it isn't much to upgrade to a stronger one if you have any doubts.
Old Feb 2, 2007 | 01:41 PM
NoGamesLS1's Avatar
Has anbody heard of one breaking?
Old Feb 2, 2007 | 02:10 PM
TwnTrboCE's Avatar
I've gone 8.50's at 168 with a stock LS1 crank in a 3700lb car. Crank was in perfect condition when the motor was pulled apart.
Harlan I believe went 8.20's or 30's at 170 with one also.
Were going to see what a LS7 crank can do in my next build. Looking for 7's.
Old Feb 2, 2007 | 04:14 PM
y2khawk's Avatar
Yep, figured it was about 1100 RWHP at that point.
And the stock crank in my truck has 30k+ miles on it at 12psi, figure that's about 500RWHP with the stock 5.3L heads on it. The crank itself has a little over 55K miles on it.
don't believe everything you read in a book
