Power increase from one cam to another.....
Old Feb 1, 2007 | 08:35 PM
Quickin's Avatar
Default Power increase from one cam to another.....
The guy who's gonna build my engine just did an LS7 heads & cam on a Z06. Ported the heads to flow 397@.650 lift and used a tiny 228 cam. He dynoed 568 RWHP.
He also just did a 416ci LS2 with L92 heads (365cfm) andL76 intake with a 230 cam. It dynoed 530 RWHP.
What power increase would a 242/242 cam give all else being equal for these two engines.
Is there a rule-of-thumb or something?
Old Feb 1, 2007 | 09:08 PM
wavrdr's Avatar
Do you know anyone local in need of an upgraded set of LS7 heads for a good price?
I'm local and looking to sell for $1,750.
Pm me if know of anyone...
Alan
Old Feb 1, 2007 | 09:37 PM
Quickin's Avatar
Alan
The LS7 heads going on my engine are from my builder. But I do know someone wanting some LS7's, I'll ask him if he's interested.
Are the heads 100% complete ready to bolt on?
Have they been ported?
Where do you live?
Old Feb 4, 2007 | 03:50 PM
GrannySShifting's Avatar
None likely, because that is the wrong cam for either of those two cylinder heads
Old Feb 4, 2007 | 03:57 PM
Stang's Bane's Avatar
x2
Old Feb 4, 2007 | 07:01 PM
Quickin's Avatar
well, what I was trying to get at is, if this builder is using such a tiny cam that idles like stock, how much more power can be had with going with a cam thats bigger, in that range, like 240's or 250's. Because my 242/242 .610/.610 114 lsa also idles close to stock in my 436ci. I need to pick a cam for him to put in my 447ci LS7 and he wants to use these small ones. I want more power if its worth it because a little lope won't kill me. He just likes small cams because he can make power either way.
Old Feb 5, 2007 | 08:29 PM
SStrokerAce's Avatar
From what I've found if you do the cam right.... zero HP at the top end.
Bret
helicoil's Avatar
Default cam
+3......
Old Feb 5, 2007 | 09:00 PM
Quickin's Avatar
Bret
Alright, what cam would you go with in 447ci engine with LS7 heads and 11.5:1 cr? Daily driver. A little lope doesn't matter. Going for as much hp as possible without being too much cam for daily driving and a sheet metal intake.
Old Feb 6, 2007 | 12:55 PM
That's not a free answer.
Old Feb 6, 2007 | 01:43 PM
Quickin's Avatar
Apparently not. I guess people just really have no clue. My builder wants me to use a tiny 230 cam that idles like stock, he says the engine will still make 600+ RWHP through my A4, but I can handle "some" lope if it'll be worth the gain. Oh well, whatever he does he does. Ordering my parts right now since I decided on a 447ci with a 4.125 stroke.
This is always a pain in the *** to do
Old Feb 6, 2007 | 01:47 PM
gnx7's Avatar
So you want to run a sheetmetal intake and put a tiny cam inside? That is counter intuitive. Sheetmetal intakes make power on the top end.... and small cams run out of breath up there.
Old Feb 6, 2007 | 02:00 PM
gtovan's Avatar
Check w/ Trail 70, he tried 3 different cams in his LS7-headed, sheet metal intake 440ci motor. Albeit, higher compression 12.8/1, but his runs could help you with your decision. His thread:
https://ls1tech.com/forums/generation-iv-internal-engine/652857-tpis-427-l92-results.html
Old Feb 6, 2007 | 02:41 PM
Quickin's Avatar
All through this thread I talk about wanting a BIG cam
Old Feb 6, 2007 | 02:46 PM
Quickin's Avatar
https://ls1tech.com/forums/showthread.php?t=652857
Thanks, I pm'ed him.
Old Feb 6, 2007 | 02:47 PM
Well it seems like you should pay someone to figure out your cam for you then????
