Who's leading the cam race for L92/L76 combos?
#61
Originally Posted by Stang's Bane
Better to keep your mouth closed and people think you a fool, than to open it and prove them right
#62
Thanks WKMCD. So i should be a bit over 500 with a good tune then. I would go bigger on the camshaft but i need a wide enough lobe seperation for a 200 hit of the funny stuff. I could probably get something ground for my specific application. Maybe like a 250/256 - .640/.640 w/ 112 lobe seperation. Is there a profile that anyone can suggest that will work better than the one i have picked out (240/246 - .600/.600 - 112). I do not drive this car as a daily driver, merely a toy. I want to go more wild than conservative, but i think i want to stay w/ 93 octane.
#63
Originally Posted by Quickin
A shop in Lauderdale. 530 RWHP from a 416ci LS2 blocked L92/L76 head&cam combo using a tiny 228 cam. Its less than 230, I'm almost certain its a 228. Idles exactly like stock.
#64
I would like info on this as well... Is 250/256 640/640 112 to big for a 402 with -2cc pistons? Cuurently having my set up built right now. 402 with Livernois Stage 2 L92's /NW 90/ etc... Just wanting something shy of max effort, but definately not mild.
Thanks.
Thanks.
#65
Originally Posted by racer7088
L92 is just an engine! It has a bigger intake port and valve. You can run a slightly smaller intake lobe and less overlap and it's not a lot more complicated than that. The more people run these things the more people will calm down but the L92 is no more magic than the LS7. An engine of X cubic inches can only make so much TQ no matter what head is on it.
True dat.
Thank God!! Someone said it!! Although I am a big supporter of these heads and what their potential is. They are not some all mighty dragon slayng,pimptastic,world destroying, Spartan crushing, baby saving, Miss America ******* head that you get for free. They are just a pretty damn good flowing head that are really good on specific applications, that are reasonably priced.
Like anything else NO head will be the best for every application.
True dat.
#66
#67
The L92 Engine/Cam/Manifold combo must work together as a package. It could be that all these wild, long duration cams are being hampered by the stock L92/L76 Intake Manifold. Once the aftermarket suppliers, such as FAST, begin making Manifolds, longer duration cams will probably produce very nice power. I will be flow testing a set of L92 heads and Intake and posting the results, before and after mods.
Paul
Paul
