Out of box VS ported L92s
Me or Kevin will post them just as soon as there on the screen
Heads are coming off now. Should have results on monday.
Has the intake been flowed?
Can the heads be flowed with the intake hooked up?
I'm going to get the stock heads cleaned up monday, and get some pictures and measurements of both heads, to get a good comparison.
But I undrstand what you are asking about. It would be interesting to see some flow #s on the intake/head combo. Hopefully those will be available soon.
Any news yet??? Inquiring minds want to know!
On a side note, hats off to wcch. It looks like there's a ton of material that can be taken out of the exhaust ports on these heads which has been proven to really be lacking. I think we're going to see a lot of L92 heads with only exhaust port work done while leaving the intake ports alone.
People keep talking about finding the right cam "for the heads" but IMO it goes beyond that. Other cam profiles will probably help some but I don't think you'll see the leaps and bounds in power gains like we did from cam profiles on the 346. Until an intake comes out that will keep up with these heads you're fighting a major bottleneck. It's like putting a coffee stirrer in your mouth then putting a regular straw at the other end and blowing through the coffee stirrer. You know the straw flows well but the stirrer doesn't so your stuck. The desparity in flow between the L76 intake and L92 heads seems much greater than LS1/LS6 intake and LS1/LS6 heads. Just my opinion.
Richard
Richard
