Cam Spec's for L76?
Old Feb 25, 2007 | 09:54 PM
67 Rally Sport's Avatar
Default Cam Spec's for L76?
Anyone know what the numbers are on this one?
Old Feb 26, 2007 | 01:52 AM
UTE 500's Avatar
I'd like to know this as well... I also would like to know if the speculation that the L76 engine has the L92 heads on it is true, and if so what size valves are fitted. I have just bought a pickup with the L76 engine fitted, and would like to know what i am dealing with. I am planning a cam swap, 1-7/8 - 3" headers and dual 3" system with cutouts. any speculation on a cam for best results?
Old Feb 26, 2007 | 09:07 AM
StingrayCrazy's Avatar
2007 GMPP Catalog says 198/209 .500/.500 on a 116
Frank
Old Feb 26, 2007 | 02:40 PM
nelson71's Avatar
Is the L76 truck engine the same as the one coming in the G8?
The truck L76 has a cam phaser right? The G8 promo material does not mention the cam phaser.
Old Feb 26, 2007 | 03:20 PM
Wnts2Go10O's Avatar
kind of... different intake manifold and possibly cam.
Old Feb 26, 2007 | 03:42 PM
Bo185's Avatar
Everything I have seen the heads are the same on the V-max L76 and L92 I have the same heads I haven't compared the casting numbers though.
And intake maybe cam and less cubes and a different tune.
Old Feb 27, 2007 | 12:53 AM
UTE 500's Avatar
Default L76 output
the GM specs of the L76 are
CAR- 362HP at 5700RPM and 391ft/lbs at 4400RPM.
Truck 360HP at 5200RPM and 380ft/lbs at 4000RPM
probably a diferent cam in the 2 engines, but not much diferent.
Old Mar 2, 2007 | 08:46 AM
S1LV3R's Avatar
Wow, the car motor makes more torque than the truck motor! Hopefully the truck has more down low and more than the car at the same 4000 the truck peaks at.
