I am lost, need help LS7 L76 setup????
Old Mar 3, 2007 | 09:54 PM
03 BUSA's Avatar
Default I am lost, need help LS7 L76 setup????
I am in the middle of putting my car back together and now that I am at the end of it there are a couple of issues that are beating me to death.
1. The L76 does not have a cable tb therefore does not have any mounting holes for my throttle bracket. What have you guys been doing/suggest?
2. The L76 does not have a vacuum line attachment at the rear of the intake for the hvac line that use to get hooked up by the map sensor.
3. The LS7 has a dry sump, however my block has a provision for the dipstick tube but I can not get my old LS1 into it. I have tried bending and what not. I do not believe the LS7 have a dipstick in the block. Correct me if I am wrong. Anyway, let me know what you guys are doing to overcome some of these issues.
Thanks for the help.
Old Mar 4, 2007 | 02:54 PM
03 BUSA's Avatar
Update: I figured out the dipstick tube issue. I had to cut some of the exhaust gasket away to get the bolt to line up. Still need help on the other 2 issues.
Old Mar 4, 2007 | 03:23 PM
See5's Avatar
If you L76 is like mine you have to break off the tab on the vacumn fitting on the back of the manifold, this will open the port.
You might try to check out the LS7 cable adapters that are available.
http://www.umiracing.com/ and Katech for leads?
Old Mar 4, 2007 | 03:42 PM
jtl12419's Avatar
I have the similar issues and concerns. I am using a FAST90 on my L76. Will post a separate thread about specific issues with this TB.
Old Mar 4, 2007 | 03:57 PM
jtl12419's Avatar
What TB are you using and how are you mounting the cable to it?
Old Mar 4, 2007 | 05:53 PM
03 BUSA's Avatar
I am using the NW tbody. I have sent a message to Katech to see what they have. Also ramairws6 says he has 2 left $30 each. I am waiting for him to get back to me.
Old Mar 4, 2007 | 09:02 PM
03 BUSA's Avatar
All issues I believe have been addressed. Got a bracket coming, need to pull off intake again for the vacuum line and I got the dipstick figured out. Thanks for the replies
Old Mar 7, 2007 | 10:22 PM
CamaroSS22's Avatar
where did you end up getting the bracket from? My l76/l92 setup on the way for texas-speed and that is the last issue that i have is some how mounting the throttle cable to the manifold some how.
Old Mar 7, 2007 | 10:53 PM
Quik's Avatar
i had this bracket made up
Old Mar 8, 2007 | 08:59 PM
03 BUSA's Avatar
Got mine from RAMAIRWS6. It was $30, hope it comes int he mail tomorrow.
