2007 Reluctor wheel
Old Mar 4, 2007 | 09:44 AM
ojoojo's Avatar
Default 2007 Reluctor wheel
Hi everybody....
I wish that if someone could help knowing about the Reluctor wheel for the new 6.2 Cadilac Esclade Engine and 5.3 GMC Sierra 2007 new design.
And I hope that someone could help me soon as possible....Thank you..
Old Mar 4, 2007 | 04:02 PM
zo6vetteman2003's Avatar
Originally Posted by ojoojo
Hi everybody....
Here is what I know. The reluctor wheel is a 58 tooth that will except and older version crank sensor as used with the older 24 tooth reluctors used in the LS1/6. Is this the kind of answer you were looking for, or do you need more info.
Old Mar 5, 2007 | 04:38 PM
427's Avatar
427
The 24X wheel can be installed in a newer engine.
The 24 and 58 use a different sensor, it does fit in the same place but you must match the sensor too the ECU/trigger wheel.
If you are more specific, someone here can probably help you sort out your problem.
Kurt
Old Mar 5, 2007 | 05:48 PM
Kurt
Kurt is correct about the sensor, the new '06-07' 58X reluctor wheel and camshaft sensing and is not compatible with pre-'06 ECMs.
