Katech cam sensor harness wire swap??
Old Mar 13, 2007 | 11:13 PM
Beast96Z's Avatar
So basically all we need to do is make sure the colors match?
Old Mar 14, 2007 | 05:23 AM
See5's Avatar
Originally Posted by DrkPhx
I tested the Katech harness before they introduced it. The prototype worked fine as does the production piece they sent. I even removed the insulation/heat cover to verify the color coding from connector to connector. Are you guys connecting the cam sensor side connector to the lower part connector (located at the bottom timing cover), or to the top part?
Plugging into the lower extension.
The upper has a different plug and won't insert although that would be "cleaner".
I ended up swapping the pins at the sensor end of the Katech harness so I could get the wire color match and upper plug to latch.
Old Mar 14, 2007 | 10:12 AM
ramairws6's Avatar
Default Plug
You can not just plug the sensor in the other way. The plug will only go together one way. Traver
Old Mar 14, 2007 | 10:21 AM
See5's Avatar
Not true, if you are talking about the firewall connector and they have not changed it.
Old Mar 14, 2007 | 11:50 AM
ramairws6's Avatar
Well on my Trans Am I could not just turn the plug around because I would have done it......would have been a little easier, but reversing the wires wasn't that bad.Traver
Old Mar 14, 2007 | 06:48 PM
DRIVER456's Avatar
Originally Posted by Katech
You can plug the harness into the vehicle harness backwards. You shouldn't have to switch wires.
I did that and it plugged in fine,No problem,Thanks............Paul
