L92, modifications to fit in a C5???
The rest of the knock sensor, cam sensor, TB stuff is cable related.
Clutch would be good info also....
The choice of clutch requires a LS1 pilot bearing and slave and TO, not LS7 or LS2 even with LS7/2 FW, or you can use heavy duty LS1/6 clutch/flywheel.
Also, is this the only alteration/modification that needs to be done...
Thanks any info...
Why can't you use the LS2 fwheel with the LS7 clutch? I have that setup in my car now and it works great, I have an LS1 though.
I totally read what you said wrong, I thought you were saying you couldn't use the LS2/LS7 clutch.
Somewhere on here I saw a picture of what needed to be modified on the LS2 block but I can''t find it now...
Here is the post:
https://ls1tech.com/forums/showthrea...ht=motor+mount
And here is the picture:
Shirl Dickey
SDRE
Shirl Dickey
SDRE
