Does anyone have Hp/Tq numbers for a 6.0L..
with the L92 heads? I see alot of 400+ builds, not much on the stock bottom end, and bores. Looking for rwhp/tq, and maybe some insight info on the cam used.
Thanks.
Thanks.
I saw this in an issue of car craft .They had a used 6.0 litre iron short block,as cast l92 heads and a mild comp cam. It was dynoed on an engine dyno with kooks headers and a carbuerated intake with an 850 holley. the engine made 551hp and 463tq at the fly wheel.It did have a carb but I feel the l76 setup would make just as much power. Also GM High Tech did a dyno test with l92 heads and a cam on ls2 engines with simalar results.
We made 402hp and 395tq to all 4 wheels on a stock bottom end Ls2 with L92 heads , L92 intake in a TB SS ,,And there is a little more romm left in the tune ..BTW cam is 581/588 224/230 114.5 lsa . With Kooks long tubes w/cats and a Vig 3400 stall. BTW stock was 293 hp and 303 tq on our mustang AWD dyno .
