IRON 408 or 414 in my C5
I like your choice of vehicles too.
The SS is nice but a gas guzzler big time eh? Mine is getting 13.8 on the highway!
I went with doweled steel main billet caps, for minimal distortion in the lower end. You could do the same to an alum block, and increase the strength, or in addition put a girdle on top of the billet caps. Depends on what you plan to do. How much do you plan to spray? If you are spraying 200 or less, IMO you'd be safe with the aluminum block with steel billet mains, and or girdle.
Anything above 200, just go with the iron, and have piece of mind that there is going to be minimal distortion when you spray it. If it's put together right, you wont have to worry about shitting rods out the bottom, or side of the block, like I did while spraying a 200 shot on an alum block.
there wasa guy on the vetteforum spraying a built LS7. think he was pushing well over 800rwhp and spraying about a 250 shot! was a really nice motor!
thanks Chris.
I'm going with an Eagle rotating assembly so I should be good on that
Marty
and anyway, lets say you crack a liner or something. then you can just get the block fitted with some carton 427 liners and go even bigger!!
Chris.
Marty
im going 408 ls2 this season im not scared and no way do i want the extra weight if the alum will handle it, and so far im ok with alum.
last year i was close to 1,000 rwhp with both stages
